Applying Dispatching rules
a9080109
Message 1 of 23
a9080109
[ FlexSim 22.0.0 ]
I would like to know if I want to use the dispatch law of edd spt st etc. to be applied in this model, what should I do0816排程模擬.fsm
Replies (22)
Message 21 of 23
moehlmann_fe
While I appreciate that you approach me directly, I would still ask you to post question that do not directly connect to the topic of this post as a new question.
I don't always have time to answer everything and also don't necessarily know the answer to everything. Other people are unlikely to look a thread as long as this one. So posting a new question will get more eyes to see it.Other people can have valuable input as well.
It also makes it easier for users with similar questions to find a post that helps them, when the answer isn't buried in a long comment thread.
Message 22 of 23
jason_lightfootVL7B4
Mark, you post many questions on this forum which often end up being long threads which are hard for support personnel to answer quickly due to the need to review the entire thread. Often these relate to basic topics which are covered in the documentation, tutorials or training - or are covered by posts that easily found using the search tools on this site.
I strongly recommend that you get FlexSim training and direct support from your distributor, particularly when you need answers in a timely fashion (as you seem to desire in this coordination attempt with Felix) or when the support is ongoing and related to a particular project or endeavour and continuity in responses is important.
This is a shared resource where users are encouraged to participate in both asking useful questions about topics that are tricky, require explanation, not clearly covered elsewhere or the reference material cannot be found, and to answer other people's questions when the user knows the answer or can provide helpful suggestions.
The more that people post duplicate questions or let questions grow, the longer it will take supporters to answer them, and the more we will suggest that timely responses should be sought directly from your distributor.
Message 23 of 23
a9080109
ok i see
