algorithm logic
algorithm logic
avantasia2012
algorithm logic
avantasia2012
[ FlexSim 7.5.4 ]
hello everyone
i want to put some algorithm,such as astar ,Origin Ant colony algorithm into agv module or node network,may i acheive this ?i want to transfer the algorithm into flexscript ,Does flexsim software can execute the logic? thanks in advance.
support5CRPZ
@liu B
Have you used the new AGV module (Process Flow) of the latest FlexSim version?
The latest version has process flow AGV template and the upgraded A-star algorithm. If you use 7.5.4 version, you need to upgrade FlexSim to latest one.
FlexSim latest 2019 version can solve the issue like amazon robot of KIVA. I recommend you to use the latest FlexSim.
email ID : support@flexsim.co.kr & support@simflex.co.kr
avantasia2012
thank you i want create my own algorithm,into agv routing, rack location planning, and so on.How can i acheive this? thank you.
benjamin_w2
Hi @liu B,
Here is a few links that you might find useful. These all apply to the latest version of FlexSim (19.2).
AGV Tutorial:
https://docs.flexsim.com/en/19.1/Tutorials/TaskLogic/Tutorial4AGVs/AGVOverview/
Key Concepts About AGV Networks:
https://docs.flexsim.com/en/19.1/WorkingWithTasks/AGVNetworks/KeyConceptsAGVNetworks/
Building AGV Network Logic:
https://docs.flexsim.com/en/19.1/WorkingWithTasks/AGVNetworks/BuildingAGVLogic/
I hope these are helpful!
braydn_t
@liu B
Did Ben' answer help you? If so could you please click the accept button? Thanks!!
