Adding custom states to a task execution process flow
marc_k
marc_k
[ FlexSim 19.1.1 ]
In Process flow there is a task execution task sequence. in the state window there are 50 states. Is there a way to add custom states there?
benjamin_w2
Hi @Marc K,
There isn't a way to directly create a custom state in FlexSim.
However, anything above state 22 rarely gets used. If you want to have a "Custom" state show up on a state chart, you could assign your task executor to a state of 25, then map 25 to a custom name in the chart properties.
I hope this helps!
braydn_t
@Marc K
Did @Benjamin W2's answer help you? If so could you click the accept button? Thanks!
