AGV
AGV
ana_t2
AGV
ana_t2
[ FlexSim 17.1.4 ]
I wrote a process flow that AGV gets an item from source and put it at a specific destination by following up the Global table. I have specified the destination in the Global Table. The problem is that the AGV does not work. I would be happy if someone can give me an hint. I also would like to mention that I use the AGV module developed by FlexSim.
Thanks a lot
agv-process-flow-23082017.fsm
raja_sekaran
Hi @Ana Ta
Since you are using task executor(AGV) process flow, you have to add AGV object in "process flow instances" to get started also i have made some changes in process flow. I have reattached your model.
agv-processflow-1.fsm
