AGV
AGV
miyeDP27D
AGV
miyeDP27D
[ FlexSim 24.2.0 ]
I am learning to work on the AGV system and I did use the tutorial. But I have two problems:
1. My AGV is not moving from the parking spot eventhough it is connected to the control points
2. I set a destination to the item that will be loaded to the AGV but it keeps changing to another destination.
I'm not sure why is it doing so AGV System_1.fsm
jason_lightfoot_adsk
You AGV's token is stuck at the pull from list "Get Next Work Point" since there is no next work point connection from its current position:
Make a connection to another CP in the loop and it should work.
miyeDP27D
The AGV is currently in the parking spot and the CP in the parking spot is connected to the AGV entry point as a parkpoint and then from the AGVentrypoint, it connects to the other work points in a loop. Am I not supposed to connect the parking spot CP to the AGVentrypoint CP as a parkingpoint?
miyeDP27D
I have changed the connection of the AGV to the AGVentrypoint cp instead and now it is not able to retrieve the task from the load item to task list. how do I overcome this? AGV System_1.fsm
The template you have chosen is one where the park point is at a work collection point, so will not work for your case.
Please refer to the answer to this post to see a summary of the different AGV templates:
logan_gold
Hi @mm_y_2406, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
