[ FlexSim 19.2.4 ]
I want to use startRecharge command to simulate agv electronic. The agv is created by the usercommand, because the agv number is flexsible.
When I use the agv network's way point logic, it did work,as the gif1.
But when I use my user command to create a new agv ,then use a customer code activity to startRecharge, it didnot work the first time,I must run second time ,and then the startRecharge command will work.Such as the gif2.
Because my model is special, I need to use the customer code activity to realize my logic. Can you tell me why it has to run second time which just like a update, is there any other way?agv-chargev1924-1.fsmagv-chargev1924.fsm
