AGV Network Customization Delegate setSpeedProfile
iago_mf
iago_mf
[ FlexSim 23.1.3 ]
Hi!
How can I identify the travelPath being calculated in the setSpeedProfile code? The way I was using is the following loop, but if it has to pass through the same path twice, it doesn't work. I would have to add some other condition. Is there any way to directly obtain a reference to the travel path?
AGV.TravelPathSection section;
int i;
for(i = 1; i <= agv.travelPath.length; i++)
if(agv.travelPath.path == path)
section = agv.travelPath;
break;
Thanks in advance!
moehlmann_fe
The travel path is actually passed in as a parameter. The header that is shown in the documentation seems to be an accidental duplicate of the getPathTravelWeight header.
Please take a look at this @Jordan Johnson.
By checking what values are passed in by assigning them to Variant variables, the correct header should look like below (as far as I can tell).
AGV agv = param(1);   // the travelling AGV
Object path = param(2); // The path the travel section is on treenode travelPath = param(3); // The current travel section treenode agvTyp = param(4); // The type of the travelling AGV
iago_mf
I hadn't realized that the header was incorrect.
Thanks @Felix Möhlmann !
