- Mute
- Permalink
- Report
I am working on a AGV Network for a Assembly Shop Floor, it has more than 40+ Cells, Each cell has entry door and Exit Door, AGV handles Frames and Boxes. If AGV needs to deliver a Frame to the cell, it can drive through (Entry door, Unload, Exit Door). For AGV’s carrying Boxes can’t drive through the cell, AGV can enter, unload the box and change its direction (Drive Through is not allowed).
And I felt without constraints on the AGV paths, AGV’s may drive through the other cells. Which are empty / unplanned. After Loading / Unloading AGV should only use paths, which are not inside a room for travelling, except the allocated room.
I felt writing “Conditional Rules” for each room/ entry path is not a very good way. I don’t have much idea about “AGV Customization Delegate” or implementing “Hooks”.
What is the best method to achieve this logic?
@moehlmann_fe @joerg_vogel_HsH
