AGV content
AGV content
M10811061
AGV content
M10811061
[ FlexSim 19.0.0 ]
Good afternoon, I'm having a problem about the max content that agv brings to my simulation. my agv only took 342 boxes to the last queue, and didn't do it again after that.
I want agv to continue carrying the box completely.
I've tried to understand it, but I'm stuck.
can someone help me
39642-1621324265466.png0518.fsm
eric_m3
Hi @Ilham, the reason the AGVs stop picking up items is because they are out of battery. They are stuck in a loop looking for a place to recharge. You can fix this in a couple of ways, the easiest is probably to click on "AGV Network" in the tree. On the "AGV Types" tab, find in the table where it says "Battery Use (A)" and change those to 0. This will make it so the AGVs never use any battery, so they never run out. Or you can also click on blank space in the process flow and set the "BatteryRechargeThreshold" and "BatteryResumeThreshold" to -1.
The other option is to set up park points that will act as charging stations for the AGVs when their batteries get low. This info from the manual can help you learn how to set those up.
M10811061
thank you very much sir, you save my time
