AGV breakdown simulation
dvajda
dvajda
[ FlexSim 24.1.0 ]
I'm trying to simulate an AGV breakdown using process flow. The logic goes like this: if a token is present there is a certain time window in which a breakdown can occur. However I'm getting some strange results while timing my tokens. Time of tokens increases before the breakdown occurs, which doesn't make any sense. What could be the cause?
moehlmann_fe
The time in "zone" is the time the token exited the zone. The breakdown started, as per your code, between 200000 and 200050. From that time on one fewer transport was available so it makes sense that the wait times for other tokens went up during that period.
