- Mute
- Permalink
- Report
[ FlexSim 20.1.1 ]
I want to add slot label to one rack manually. What I did is adding the "slotLabels" and "resetLabels" into the tree of rack2. Then I test if it works by using the "Matching Labels" strategy. But it didnot work.
Here is the test model, in the model I use the "slot label painter" to add slot label to rack1 which worked well, I added slot label manually as mentioned which worked badly.
I wonder if I missed any steps? Looking forward to your answer.
