Add a object created by the process flow in a group
FlavioLopes
FlavioLopes
[ FlexSim 25.0.4 ]
In this simulation, I need a feature that adds each new 3D object created by the Process Flow to a Group. What is the best way to implement this feature?
Example1.fsm
gustavo_teodoroD8NVF
First, create a Group in which the items will be placed.
Next, incorporate the following command into the process flow:
Group("Group1").addMember(token.pier);
Please refer to the attached example for further clarification.
example1_solution.fsm
FlavioLopes
Gustavo,
After add the new object to the Group I want to use it as a Resource, but when I tried to Acquire Resource, the simulation doesn't seen to understand that are Resources avaliable in the Group, do you have a sugestion of what I have to do in this case?
Example 1.fsm
