A way to change a label in all the code?
jouky_d
jouky_d
[ FlexSim 23.1.2 ]
Hello everyone,
Is there a way to find or/and replace a label name to another label name in all the code inside a processFlow? And in the code?
Using Python or R we can see all the code and edit it directly. Is there a way to do the same in FlexSim?
Thank you!
jason_lightfoot_adsk
Open a tree view for the model and use the find/replace tool in the properties panel.
jouky_d
Thank you!
However, it would be interesting to see all the code, I think it can be exported or imported doesn't it?
When you run the 'find' - it lists all the matches in the Find window. You can double-click on each of the entries to view any code found containing your search expression.
