- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 22.2.0 ]
Dear reader,
I've been regularly having projects in which we develop a layout. The client often need to use the result of our study to be an input for other people/software. The current problem with FlexSim is that we can only export a capture of a view which does not provide sizing and positioning information.
- Is there a possibility for you to develop some kind of .dwg export using a projection of objects with shown shape ?
- Or is it possible to include a feature adding a grid over the capture to allow an easier copy of the layout into another software ?
Another thing I would like to mention is that increasing the resolution of the captured view does not behave as it probably should. When increasing the resolution, the result is not the current view with just a better resolution but is the current view zoomed out. Which means that the current view area does still has the same resolution but the resulting image includes a more larger area that just the one shown in the view window. Is that normal ?
Best regards,
Val
