2 Operator following different items according to a label with PF
victor_alejandro_ht
victor_alejandro_ht
[ FlexSim 18.2.0 ]
Hi all,
I have 2 operators following items in a conveyor, I need that every token has a value of 0 or 1 in a secuence, if the value is 0 operator 3 follows the item and if the value is 1 operator 4 follows the item. I create a logic with process flow like this:
But I can not make that the token goes to Conector 2. I attached my model. Thanks in advance for your help.
conveyor-unload.fsm .
Alejandro
joshua_s
Just change the label value to what is shown in the picture below and it should work fine.
victor_alejandro_ht
Thank you, Joshua it worked. After that I realized that I must adjust my logic in order to get the behaviour that I needed.
I attached the final model in case someone need it.
2-operators-follows-labeled-items.fsm
