17 Update 1 Manual Font Hard To Read!
stan_e_davis
Message 1 of 14
stan_e_davis
I first sent an email to support, but received the canned response.
You guys changed the font on the 2017 Update 1 manual. It is very hard to read. Can you re-issue it with an easier-to-read sans serif font like before? Thanks.
Replies (13)
Message 2 of 14
matt_long
The user manual font hasn't been changed. The font is set to the Helvetica Font Family, which is Helvetica and Arial, both san-serif fonts. What does your user manual look like?
Message 3 of 14
Matthew_Gillespie
He's talking about the PDF file you can download
Matthew Gillespie
FlexSim Software Developer
Message 4 of 14
stan_e_davis
For the PDF I downloaded today (5/24/17), Helvetica has been replaced with Courier.
Message 5 of 14
stan_e_davis
Here is a pic of the difference...
Message 6 of 14
Ben_WilsonADSK
I don't know why the dev team has chosen to publish the .pdf user manually differently for the latest version. Perhaps they will chime in.
Serif vs Sans Serif is largely a matter of taste or preference. Designers will choose one or the other based on their goals. Perhaps another user requested serifs for their printed manuals, and this is another case of "you can't please all the people all the time."
The in-software manual remains sans:6786-2017-05-24-14-45-27-flexsim-2017.png
In the latest versions of Microsoft Word, you can open PDF files, at which point you can change the font to whatever you like best. I've just tested this on the 17.1.0 user manual, and globally changed the font to Arial, with the result attached here:
flexsim-1710-manual-arial.pdf
Message 7 of 14
Ben_WilsonADSK
It is actually Times New Roman, according to Microsoft Word upon opening the PDF.
Message 8 of 14
stan_e_davis
Putting the 'you can't please all the people' comment to the side, I was just bringing it up that the fact the font has changed from what we have seen through the years and is presently harder to read. You guys want customer feedback, right? Yes, you can open the pdf in Word, but the conversion is not perfect.
Message 9 of 14
Ben_WilsonADSK
We do want and value your feedback, @Stan Davis. If the change was an oversight or a whim, then I'm sure this can be changed back based on your feedback. If the change was due to other feedback I'm not aware of, the dev team will certainly take yours into consideration, in addition to whatever prompted the change in the first place.
Message 10 of 14
Ben_WilsonADSK
@Stan Davis,
Looks like the font change was a result of a technical problem in the automatic build.
We're doing a manual build now to see if we can fix the problem and will post an update to this Answer when it completes.
Message 11 of 14
matt_long
It looks like Microsoft Word 2016 can't correctly export an HTML file to PDF. I've uploaded the corrected PDF manual to the downloads section of the FlexSim website. You can access it here:
FlexSim Downloads
Message 12 of 14
stan_e_davis
I appreciate the effort with this. However, the corrected manual has missing images throughout the entire manual. I downloaded it twice to verify the issue. Pages 53, 56, 63, 64, 68, 69, 71, ...1584.
Here is a pic comparing the initial manual with the revised manual...
Message 13 of 14
matt_long
Thanks for pointing that out. I've uploaded a new version to the FlexSim website and I've confirmed that those images are there.
Message 14 of 14
stan_e_davis
Thanks for the support, Matt. We're good to go.
