Visualising Audio waveforms
adamt
Message 1 of 11
adamt
I've already posted this in the ghost town known as Smoke Area, so apologies if you've already seen it.....
does anyone know a way to visualise an audio input as a waveform within CFX/Action?
I have the Logik Matchbox sparks and the Genarts Sapphires but nothing looks obvious.
Perhaps there is a way to drive the amplitude of an axis node using volume levels?
I know i can do this easily in After Effects but i would rather stay within Smoke.
thanks
Adam
Flame 2020.3
Replies (10)
Message 2 of 11
bryan.kenny
Hi Adam,
Not sure if this is what you're looking for, but you can generate keyframes based on audio analysis, from the Audio tab in the Channel Editor. See this Help topic for details: http://help.autodesk.com/view/FLAME/2018/ENU/?guid=GUID-A7EB45DE-4686-4968-B418-F0A41BD86B51
Please click the Accept as Solution button if my post fully solves your issue or answers your question.
Bryan Kenny
Help-Learn Tech Writer
Message 3 of 11
adamt
thanks Bryan - sounds like what i need...but that link is broken!
regards
Adam
Flame 2020.3
Message 4 of 11
bryan.kenny
Oops, sorry...try this one:
http://help.autodesk.com/view/SMOKE/2017/ENU/?guid=GUID-A7EB45DE-4686-4968-B418-F0A41BD86B51 (Smoke 2017)
Bryan Kenny
Message 5 of 11
adamt
that worked...thanks Bryan.
now i need to figure out how to use the keyframes to generate a waveform!
adam
Flame 2020.3
Message 6 of 11
joelosis
Message 7 of 11
adamt
thanks Joel
Flame 2020.3
Message 8 of 11
jasper.brandt
Hi Adam,
i created a shader just to play around with audio inside Flame
WIP: Audio Visualization - Matchbox Shader for Autodesk Flame / Flare / Smoke
its really simple and i can send the shader to you if you like it.
./ivar
Message 9 of 11
adamt
wow, that looks interesting Ivar...thank you. Its exactly the kind of effect i was looking for.
Yes please, i'd love to have a play with that shader!
Adam
Flame 2020.3
Message 10 of 11
jasper.brandt
Hi Adam,
see below for the shader.
You need 3 frequencies to animate the shader (Low, Mid, High)
you have to extract the animation curves from your audio file and then link them to the 3 shader values you extracted.
Have fun!
./ivar
PS: Autodesk can you please fix the attachment ! I can't attach a GLSL File 😞
Message 11 of 11
adamt
brilliant...look forward to playing with this!
thank you.
Flame 2020.3
