Hi!
I have three questions about shots sequence.
1. Is it possible to import a edit (xml, aaf etc.) after you have created and conformed a shot sequence and sync the new edit to the already existing shots sequence?
2. Can multiple users work on the same shots sequence, maybe through shared libraries?
3. When you create a batch group and put it in shared libraries, how do you work on them batches? I would like to be able to share the batches with other users and they get updated once the others has rendered and saved the comp.
Is this possible?
I use the Flame 2022 version.
