Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
Maybe QT was broken
6 REPLIES 6
1399 Views, 6 Replies
Maybe QT was broken
run "/opt/Autodesk/flame_2022.0.1/bin/startApplication" not work,
"/opt/Autodesk/flame_2022.0.1/bin/flame"is fine.
log is here
Fatal: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
INFO:flame202201:Fatal: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
INFO:flame202201:
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
INFO:flame202201:Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
Output log to: '/opt/Autodesk/log/vref.log'.
INFO:flame202201:Output log to: '/opt/Autodesk/log/vref.log'.
[VREF]: shutdown completed
INFO:flame202201:[VREF]: shutdown completed
Stopping managed threads.
INFO:flame202201:Stopping managed threads.
......  maybe some package was auto upgrade before I've installed epel+rpmfusion
Maybe QT was broken
log is here
INFO:flame202201:
6 REPLIES 6
Had similar issue, problem was with my user account. Try it run under root account if you can. Solution for my was to create new user account with admin access, reinstal flame under this user and it worked. Seems like problem with Centos 8.2.
fred.warren
fred.warren
Hello @Anonymous,
Please communicate with the support team so they can help you investigate this issue.
fred
Frédéric Warren
User Experience Designer
Hello @Anonymous,
fred
Frédéric Warren
tried but not work...
in reply to: fred.warren
OK thanks
OK thanks
uirado
uirado
Observer
Observer
Go to terminal and put:  echo $DISPLAY
after, in terminal:
sudo nano  /opt/Autodesk/cfg/env.cfg
and and change the value to match the result of "echo $DISPLAY"
ex.:
if the value is 0 change and $DISPLAY is 1 so change to 1 or if 1 change and $DISPALY is 0 so change to to 0.
ctrl+x and yes to exit saving file.
Start Flame
Will work.
after, in terminal:
ex.:
Start Flame
Will work.
julioleonb
in reply to: uirado
julioleonb
Community Visitor
Community Visitor
Thanks Uirado
Thanks Uirado
