Lens Flare Presets
Lens Flare Presets
sztom998
Lens Flare Presets
sztom998
I can't change the lens flare presets. What happens?
fred.warren
Hello @sztom998,
Many changes have been made in the 2025 version to reduce te amount of files added on disk, standardize the usage of presets throughout the application, and allow you to save presets at different levels. In the case of Lens Flare, the Autodesk presets are still available from the Presets node in Action and you can now save your own presets in your user profile or in a central location from the Lens Flare node's using the Save button.
I encourage you to have a look at these videos on the Flame Learning Channel for more information:
fred
Frédéric Warren
User Experience Designer
sztom998
Indeed, it worked fine on the previous version. But now it cannot be replaced normally on 2025.2.2. Maybe this problem only exists on the Mac version? Thanks.
sztom998
For now, I load every lens flare presets, and save them. It's working now.
