Flame 2022 Trial not starting
Message 1 of 16
Hello everyone
I want to try install flame 2022 trial to on my Mac pro but not starting.
IFFS error giving me.
Replies (15)
Message 2 of 16
jeffrey.ramirez
Hi @Anonymous,
I hope you are doing well.
Do you have any previous Flame install on the same machine? Are any of the network connections active or connected?
Please check this article and see if it helps:
https://knowledge.autodesk.com/article/Local-Wiretap-IFFFS-service-not-running-Connection-refused-pr...
Jeff
Message 3 of 16
Thank you for your reply..
before this situation i was on big sur. Something went wrong and flame not opened just flame icon jumped and jumped..
i reformat my computer and clean install catalina,  now ifffs service error..
on my network only 1 win 10 machine runing..and second computer my mac..
i tried to disconnect network and connect with iphone hotspot.. nothing changed..
any advice could you give for solution ?
Message 4 of 16
jeffrey.ramirez
In macOS System Preferences > Security and Privacy > Privacy > Full Disk Access > Make sure the following are checked (Allowed). Note that some of them may not appear yet.
  • ifffsWiretapServer
  • wiretapgateway
  • DLmpd
  • sw_serverd
  • Flame
If the issue persist, please send here these log files:
  • /opt/Autodesk/log/flame_<hostname>_app.log
  • /opt/Autodesk/log/flame_<hostname>_shell.log
  • /opt/Autodesk/log/wiretapgateway.log
  • /opt/Autodesk/log/ifffsWiretapServer.log
  • /opt/Autodesk/sw/log/sw_serverd.log
An alternative way to collect the log files, if you are familiar with the use of terminal (command line), you may execute this script:
sudo /opt/Autodesk/flame_2022/bin/ftpuploadlogs --days=2
Note: you may copy and paste the entire line above and hit enter in the Terminal app. Once executed it will tell you where the compressed log files are saved. Please send us the compressed file.
Jeff
Message 5 of 16
Hello.
im not it professional. I will get help from my friend after vacation of covid-19. And share to you.
Thank You
Message 6 of 16
hola again
in /opt/autodesk/cfg/network.cfg “meta= “value empty default
if you changes that value to “Meta=eth2” problem gone
it seems that solving wiretap gateway service to normal working now.
thanks all answer
Message 7 of 16
carlosespinosanitris
Observer
Observer
Good evening Jeffrey,
I'm having the same problem after installing Flame, After two years of stopping working on flame, I'm going on track again and I need to start engines. attached is the info you'll need.
Thank you for your help.
Carlos.
Message 8 of 16
abraham.borbujo
Hi Carlos,
In your case, it looks like you are using macOS Monterrey (12.x.x).
Flame 2022 trial version is not compatible yet with that macOs version.
At this moment, Flame 2022.2 subscription version is required for macOS Monterrey.
Flame Family 2022 release system requirements
Abraham
Message 9 of 16
Observer
Observer
OHHH Noooo! it's ok.
Thank you so much, I should check the system requirements before. 😓
Thanks again Abraham.
Message 10 of 16
abraham.borbujo
No problem. My pleasure.
Abraham
Message 11 of 16
perseus1
Hi
I am running the latest verison of Flaem on my mac studio OS Monterey. flame installs fine, it is possible to set the framestore to a local disk, create a project and ingest footage and play it. its NOT possible to do anything much else, certainly not using Action. If I try to enter Action, I get the spinning wheel of death and have to do a hard reboot. Id flame not supported on the new Mac Studio?  If not, can I ask if it ever will be? 😛
regards
David
Message 12 of 16
yann.laforest
Hi @perseus1,
Flame should run on the new Mac Studio.
You said that you run the latest version of Flame.
Would you mind specifying if it is the Trial or Commercial version?
Best,
Yann
Yann Laforest
Principal Data Scientist Autodesk AEC
10 rue Duke Street
Montréal (Québec) Canada H3C 2L7
Message 13 of 16
perseus1
Oh, and its the commercial version, sorry
D
Message 14 of 16
yann.laforest
Thanks, @perseus1.
Can you please confirm that you run Flame 2022.3?
Best,
Yann
Yann Laforest
10 rue Duke Street
Message 15 of 16
perseus1
Hi Yann
I have installed version 2023, I hav eno. Idea if it’s 2023.3 and cannot find anywhere that will tell me what sub version it is. I can create a project and star **** up, I cannot get the player to display anamorphic clips with the corrected aspect ratio. On the desktop reels they display fine, but in the player they are not in the correct aspect ratio (to be honest, I always forget what this setting must be, I have looked in preferences and in the controls and options of the player, but no luck, what am I missing?)
I have not tried to do anything further other than start a project and also try to find out if the version 2023 is indeed 2023.3
Any ideas?
Best regards
David
Message 16 of 16
yann.laforest
Thanks, David.
Flame 2023 is being released today, so I assumed that you were still on Flame 2022.  The latest Flame 2022 version available is 2022.3.
Troubleshooting such issues over a discussion forum is challenging so I recommend opening a ticket with our technical support and having it checked out by one of our engineers.
https://knowledge.autodesk.com/support/flame-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Please, let me know if you have any questions.
Best,
Yann
Yann Laforest
10 rue Duke Street
