Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
first time client: apply a LUT to a gathering of shots in s Sequence?
1 REPLY 1
supportXUZHM
189 Views, 1 Reply
The Difference Between Softball and Baseball Bats
Baseball versus softball bats
The Bat Nerds select and survey items autonomously. On the off chance that you purchase through the subsidiary connections on our site, we might acquire commissions which assist with supporting our testing, at no extra expense for you.
There are numerous distinctions among baseball and softball. From the size of the ball to the aspects on the field to the size of the bat in the player's container, these games look amazingly comparable yet are fabricated in an unexpected way.
One of the biggest of these distinctions is the bat that the hostile player takes with them into the hitter's container every inning.
Here, we will separate how the two kinds of bats vary across every one of the various forms of play from youth sports to ease back pitch to fastpitch.
The Length Is Different
A polished ash is more modest than a typical softball bat by around one inch
In all honesty, the typical slugger is as a matter of fact more modest than the typical softball bat by about one inch.
The typical play club is about 33 creeps from handle to end, while the typical softball bat is a full inch longer at 34 inches.
A more drawn out bat in softball accommodates better plate security as hitters make some more limited memories to decide if the pitch will be a strike in view of the way that the pitcher is on similar level as they are and nearer to home plate.
On the baseball side, a somewhat more modest and heavier bat is simpler to traverse the strike zone and connect. On one more intriguing note, on the young level, there is no distinction.
The typical size in both youth baseball and softball is a 30-inch bat, and this is probable since youngsters are managing similar issues and are generally basically as solid as each other notwithstanding the orientation and game contrasts.
1 REPLY 1
slabrie
in reply to: supportXUZHM
Hello SupportXUZHM!
Welcome to Flame!
There are many ways to apply LUT in Flame.  As I understand, you have multiple shots in a sequence and the fastest way to apply a LUT to these shots is the following
-Add a Video Track on top of your sequence (T+ button located bottom left of Timeline environment)
-Select the gap on the track
-Right-click and select Add Effect
-Select Color Management FX
-Press Colour Transform drop down and select 3D LUT
-Set Tagged Colour Space to the Colour Space of your choice (Probably Rec.709 video from Broadcast section)
-Press Import and import your LUT
if you have shot based LUT, the same process can be done by applying the Colour Management FX on a shot basis instead of using a gap on top of your content.
Have a look at Flame online help for more information on how to work with Colour Management (https://help.autodesk.com/view/FLAME/2022/ENU/?guid=GUID-E5BD9BB6-1DEB-44C4-9256-59EAEA0B14AE)
Please share with us your experience as a new Flame artist.
Stéphane Labrie
Senior Product Owner
Flame Family
