F2018.3 Project is in recovery mode
Since I had a bad crash, one of my projects is in recovery mode. It says also that the integrity check is missing/failing.
When I am running /opt/Autodesk/io/bin/vic -a, I get:
Header for /opt/Autodesk/clip/stonefs/project.prj/Workspace.wksp/.#workspace.000.wks cannot be read or is incompatible.
Unable to extract frameids from libraries
Integrity check failed to proceed.
 I followed this instruction:
https://knowledge.autodesk.com/support/flame-products/troubleshooting/caas/simplecontent/content/fla...
So I run (root)
/opt/Autodesk/io/bin/vic -v stonefs0
But still get the same result like above.
My setup: Linux, Flame 2018.3. Flame 2019 is installed but not running. (we need to update the license server)
Thx,
Henrik
jeffrey.ramirez
Hi Henrik,
Aside from the message "Project Volume is in Recovery Mode", your Workspace in the project "project" looks to be corrupted as well:
To try to recover it, please check and follow the instruction in this article:
The article shows solution on how to recover corrupted library, but the process should be the same with "Workspace" recovery.  I recommend that you backup your project metadata first as well as the project _AUTO_BACKUP before the recovery process, from your output they should be as follows:
/opt/Autodesk/clip/stonefs/project_AUTO_BACKUP
Hope this helps.
**Please accept this as a solution if you feel your question has been answered.
Jeff
Hi Jeffrey,
Thanks for your help. It worked.
The only bummer was that my workspace.001 was pretty old. It is ok because I am doing just batch in that project and I had all my iterations. But I thought workspaces get saved too by saving the project.
Thank you!
I am pretty new in Flame, I guess I have to read a lot more how Flame works under the hood. How the project, media, and workspace structure is built...
jeffrey.ramirez
You're welcome Henrik. Please feel free to post here in the forum if you encounter any issues or would like to get advise from the other user/artist in the community. Please also checkout these useful links:
Consolidated page for all Flame related documents:
https://area.autodesk.com/flame-central/
Flame Learning Channel:
https://www.youtube.com/user/FlameHowTos
Jeff
thank you!
