Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
Cache imported media with Python
2 REPLIES 2
jonas.lindfors
372 Views, 2 Replies
I'm importing an image sequence with python and when it's imported I want to cache the media, but I can't get it to work..
This is my code:
import flame
#path to image sequence
clip_path = '/mnt/VFX_PROJECTS/path_to_my_sequence/200_010_PLATE_v001.[1001-1015].exr'
# Grabbing a folder in library
folder = flame.project.current_project.current_workspace.libraries[1].folders[0]
# importing the clip (which works fine)
imported_clip = flame.import_clips(clip_path, folder)[0]
# trying to cache the clip
imported_clip.cache_media()
And it errors out with
RuntimeError: Clip no longer exist.
Does anyone know what I'm doing wrong here?
I'm on Flame 2020.1 / linux
Jonas
Tags (2)
2 REPLIES 2
stefan-g
in reply to: jonas.lindfors
I'm far from a python expert so please forgive my approximations ...
I originally thought that your imported_clip object only existed at import time.
I tried the following (replacing the end of your script) and it worked:
my_clip = flame.project.current_project.current_workspace.libraries[1].folders[0].clips[0]
print "my_clip name: ", my_clip.name
my_clip.cache_media()
BUT ... then i tried again your version, only living the line defining 'my_clip' from my added stuff...
And it worked! Somehow defining 'my_clip' (as the clip you just imported) revived your 'imported_clip'
Don't know what's going on ...
Stefan
jonas.lindfors
in reply to: stefan-g
Hi Stefan, thanks for this!
Interesting. So if I understand you correctly, you defined my_clip variable pointing to:
And then you could still  use the original variable which I called "imported_clip" ?
I will definitely try this out.
Using flame.project.current_project.current_workspace.libraries[1].folders[0].clips[0] would not necessarily give me the clip that I just imported, but instead the first clip in the list of clips in that folder. But I guess I could always use that list and loop to find the clip that I just imported otherwise.
Thanks a lot, will try it out as soon as I get my hands on one of our Flames again hehe..
