I removed all directories of Autodesk and I tried to install Autodesk Flame 2018 but I got the message installation failed.I have Mac Sierra 10.12.5. Below is the installation log and any help would be really appreciated. Thank you!
/private/var/tmp/autodesk/Installer.log
2017-04-22 22:54:16:024 : Component: Flame not scheduled and disabled because already installed
2017-04-22 22:54:16:489 : Component: WTC not scheduled and disabled because already installed
2017-04-22 22:54:16:491 : Component: Flame not scheduled and disabled because already installed
2017-04-22 22:54:16:492 : Component: WTC not scheduled and disabled because already installed
2017-04-22 22:54:19:723 : Component: Flame not scheduled and disabled because already installed
2017-04-22 22:54:19:724 : Component: WTC not scheduled and disabled because already installed
2017-04-22 22:54:19:725 : Component: Flame not scheduled and disabled because already installed
2017-04-22 22:54:19:726 : Component: WTC not scheduled and disabled because already installed
2017-04-22 22:54:25:127 : TStpInstPkgHandler::setup - started
2017-04-22 22:54:25:169 : Installer error stream: authinstalltool: beginning run
2017-04-22 22:54:25:169 : Installer error stream: authinstalltool: Checking self repair
2017-04-22 22:54:25:169 : Installer error stream: authinstalltool: reading command.
2017-04-22 22:54:25:169 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-04-22 22:54:25:170 : Sending marshaled authorization.
2017-04-22 22:54:25:170 : TStpInstPkgHandler::setup - install_volume = /
2017-04-22 22:54:25:170 : TStpInstPkgHandler::setup - write = 1
2017-04-22 22:54:25:173 : Installer error stream: authinstalltool: Not running with privileges. Invoking self-repair
2017-04-22 22:54:25:173 : Installer error stream: authinstalltool: Creating named pipe.
2017-04-22 22:54:25:199 : Installer error stream: authinstalltool: beginning run
2017-04-22 22:54:25:199 : Installer error stream: authinstalltool: Checking self repair
2017-04-22 22:54:25:200 : Installer error stream: authinstalltool: Self repairing
2017-04-22 22:54:25:203 : Installer error stream: authinstalltool: self-repair done.
2017-04-22 22:54:25:203 : Installer error stream: authinstalltool: Should now have privileges.
2017-04-22 22:54:25:203 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-04-22 22:54:25:203 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-04-22 22:54:25:204 : Installer error stream: authinstalltool: Installing Install Flame.app/Contents/Resources/dist/clmv4.2.1.pkg on target:/
2017-04-22 22:54:25:204 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame.app/Contents/Resources/dist/clmv4.2.1.pkg -target / -verboseR
2017-04-22 22:54:25:812 : process stdout:installer: Package name is clmv4.2.1
2017-04-22 22:54:25:812 : Installer output: installer: Package name is clmv4.2.1
2017-04-22 22:54:25:813 : process stdout:installer: Upgrading at base path /
2017-04-22 22:54:25:813 : Installer output: installer: Upgrading at base path /
2017-04-22 22:54:25:813 : process stdout:installer:PHASE:Preparing for installation…
2017-04-22 22:54:25:837 : process stdout:installer:PHASE:Preparing the disk…
2017-04-22 22:54:25:852 : process stdout:installer:PHASE:Preparing clmv4.2.1…
2017-04-22 22:54:25:866 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-04-22 22:54:25:867 : process stdout:installer:PHASE:Configuring the installation…
2017-04-22 22:54:25:868 : process stdout:installer:STATUS:
2017-04-22 22:54:25:868 : Installer Status:
2017-04-22 22:54:26:368 : process stdout:installer:%6.804286
2017-04-22 22:54:26:370 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:26:867 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:27:369 : process stdout:installer:%8.729051
2017-04-22 22:54:27:371 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:27:869 : process stdout:installer:PHASE:Validating packages…
2017-04-22 22:54:28:372 : process stdout:installer:PHASE:Validating packages…
2017-04-22 22:54:28:876 : process stdout:installer:%97.750000
2017-04-22 22:54:28:877 : process stdout:installer:STATUS:
2017-04-22 22:54:28:877 : Installer Status:
2017-04-22 22:54:28:877 : process stdout:installer:PHASE:Finishing the Installation…
2017-04-22 22:54:28:878 : process stdout:installer:STATUS:
2017-04-22 22:54:28:886 : Installer Status:
2017-04-22 22:54:28:886 : process stdout:installer:%100.000000
2017-04-22 22:54:28:886 : !!!!Done!!!!!!
2017-04-22 22:54:28:886 : process stdout:installer:PHASE:The software was successfully installed.
2017-04-22 22:54:28:887 : process stdout:installer: The upgrade was successful.
2017-04-22 22:54:28:887 : Installer output: installer: The upgrade was successful.
2017-04-22 22:54:28:888 : Exited
2017-04-22 22:54:28:888 : TStpInstPkgHandler::setup - Exit status 0
2017-04-22 22:54:28:888 : TStpInstPkgHandler::setup - Exit Complete
2017-04-22 22:54:29:165 : TStpInstPkgHandler::setup - started
2017-04-22 22:54:29:182 : Installer error stream: authinstalltool: beginning run
2017-04-22 22:54:29:182 : Installer error stream: authinstalltool: Checking self repair
2017-04-22 22:54:29:183 : Installer error stream: authinstalltool: reading command.
2017-04-22 22:54:29:183 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-04-22 22:54:29:183 : Sending marshaled authorization.
2017-04-22 22:54:29:183 : TStpInstPkgHandler::setup - install_volume = /
2017-04-22 22:54:29:184 : TStpInstPkgHandler::setup - write = 1
2017-04-22 22:54:29:187 : Installer error stream: authinstalltool: Should now have privileges.
2017-04-22 22:54:29:187 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-04-22 22:54:29:187 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-04-22 22:54:29:188 : Installer error stream: authinstalltool: Installing Install Flame.app/Contents/Resources/dist/AdSSO-v2.pkg on target:/
2017-04-22 22:54:29:188 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame.app/Contents/Resources/dist/AdSSO-v2.pkg -target / -verboseR
2017-04-22 22:54:29:649 : process stdout:installer: Package name is AdSSO-v2
2017-04-22 22:54:29:649 : Installer output: installer: Package name is AdSSO-v2
2017-04-22 22:54:29:649 : process stdout:installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2017-04-22 22:54:29:649 : Installer output: installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2017-04-22 22:54:29:652 : Exited
2017-04-22 22:54:29:652 : TStpInstPkgHandler::setup - Exit status 1
2017-04-22 22:54:29:652 : !!!! ListPage: ExceptionMessage(3):Installation failed on Exit
2017-04-22 22:54:29:807 : TStpInstPkgHandler::setup - started
2017-04-22 22:54:29:825 : Installer error stream: authinstalltool: beginning run
2017-04-22 22:54:29:825 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-04-22 22:54:29:826 : Sending marshaled authorization.
2017-04-22 22:54:29:826 : TStpInstPkgHandler::setup - install_volume = /
2017-04-22 22:54:29:826 : TStpInstPkgHandler::setup - write = 1
2017-04-22 22:54:29:826 : Installer error stream: authinstalltool: Checking self repair
2017-04-22 22:54:29:826 : Installer error stream: authinstalltool: reading command.
2017-04-22 22:54:29:830 : Installer error stream: authinstalltool: Should now have privileges.
2017-04-22 22:54:29:830 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-04-22 22:54:29:830 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-04-22 22:54:29:831 : Installer error stream: authinstalltool: Installing Install Flame.app/Contents/Resources/dist/adlmapps12.pkg on target:/
2017-04-22 22:54:29:831 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame.app/Contents/Resources/dist/adlmapps12.pkg -target / -verboseR
2017-04-22 22:54:30:122 : process stdout:installer: Package name is adlmapps12
2017-04-22 22:54:30:123 : Installer output: installer: Package name is adlmapps12
2017-04-22 22:54:30:123 : process stdout:installer: Upgrading at base path /
2017-04-22 22:54:30:123 : Installer output: installer: Upgrading at base path /
2017-04-22 22:54:30:123 : process stdout:installer:PHASE:Preparing for installation…
2017-04-22 22:54:30:133 : process stdout:installer:PHASE:Preparing the disk…
2017-04-22 22:54:30:146 : process stdout:installer:PHASE:Preparing adlmapps12…
2017-04-22 22:54:30:159 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-04-22 22:54:30:160 : process stdout:installer:PHASE:Configuring the installation…
2017-04-22 22:54:30:160 : process stdout:installer:STATUS:
2017-04-22 22:54:30:160 : Installer Status:
2017-04-22 22:54:30:663 : process stdout:installer:%2.229250
2017-04-22 22:54:30:665 : process stdout:installer:PHASE:Validating packages…
2017-04-22 22:54:31:161 : process stdout:installer:%97.750000
2017-04-22 22:54:31:164 : process stdout:installer:STATUS:
2017-04-22 22:54:31:165 : Installer Status:
2017-04-22 22:54:31:165 : process stdout:installer:PHASE:Finishing the Installation…
2017-04-22 22:54:31:165 : process stdout:installer:STATUS:
2017-04-22 22:54:31:166 : Installer Status:
2017-04-22 22:54:31:166 : process stdout:installer:%100.000000
2017-04-22 22:54:31:166 : !!!!Done!!!!!!
2017-04-22 22:54:31:166 : process stdout:installer:PHASE:The software was successfully installed.
2017-04-22 22:54:31:167 : process stdout:installer: The upgrade was successful.
2017-04-22 22:54:31:167 : Installer output: installer: The upgrade was successful.
2017-04-22 22:54:31:167 : Exited
2017-04-22 22:54:31:167 : TStpInstPkgHandler::setup - Exit status 0
2017-04-22 22:54:31:168 : TStpInstPkgHandler::setup - Exit Complete
2017-04-22 22:54:31:320 : TStpInstPkgHandler::setup - started
2017-04-22 22:54:31:337 : Installer error stream: authinstalltool: beginning run
2017-04-22 22:54:31:338 : Installer error stream: authinstalltool: Checking self repair
2017-04-22 22:54:31:338 : Installer error stream: authinstalltool: reading command.
2017-04-22 22:54:31:338 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-04-22 22:54:31:339 : Sending marshaled authorization.
2017-04-22 22:54:31:339 : TStpInstPkgHandler::setup - install_volume = /
2017-04-22 22:54:31:339 : TStpInstPkgHandler::setup - write = 1
2017-04-22 22:54:31:343 : Installer error stream: authinstalltool: Should now have privileges.
2017-04-22 22:54:31:343 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-04-22 22:54:31:343 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-04-22 22:54:31:344 : Installer error stream: authinstalltool: Installing Install Flame.app/Contents/Resources/dist/adlmframework12.pkg on target:/
2017-04-22 22:54:31:344 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame.app/Contents/Resources/dist/adlmframework12.pkg -target / -verboseR
2017-04-22 22:54:31:732 : process stdout:installer: Package name is adlmframework12
2017-04-22 22:54:31:732 : Installer output: installer: Package name is adlmframework12
2017-04-22 22:54:31:732 : process stdout:installer: Upgrading at base path /
2017-04-22 22:54:31:732 : Installer output: installer: Upgrading at base path /
2017-04-22 22:54:31:732 : process stdout:installer:PHASE:Preparing for installation…
2017-04-22 22:54:31:762 : process stdout:installer:PHASE:Preparing the disk…
2017-04-22 22:54:31:775 : process stdout:installer:PHASE:Preparing adlmframework12…
2017-04-22 22:54:31:787 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-04-22 22:54:31:788 : process stdout:installer:PHASE:Configuring the installation…
2017-04-22 22:54:31:795 : process stdout:installer:STATUS:
2017-04-22 22:54:31:795 : Installer Status:
2017-04-22 22:54:32:290 : process stdout:installer:%6.070349
2017-04-22 22:54:32:292 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:32:793 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:33:290 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:33:788 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:34:291 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:34:791 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:35:292 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:35:790 : process stdout:installer:%31.730242
2017-04-22 22:54:35:793 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:36:292 : process stdout:installer:%53.508861
2017-04-22 22:54:36:293 : process stdout:installer:PHASE:Removing old files…
2017-04-22 22:54:36:787 : process stdout:installer:PHASE:Validating packages…
2017-04-22 22:54:37:802 : process stdout:installer:%97.750000
2017-04-22 22:54:37:805 : process stdout:installer:STATUS:
2017-04-22 22:54:37:806 : Installer Status:
2017-04-22 22:54:37:806 : process stdout:installer:PHASE:Finishing the Installation…
2017-04-22 22:54:37:806 : process stdout:installer:STATUS:
2017-04-22 22:54:37:807 : Installer Status:
2017-04-22 22:54:37:807 : process stdout:installer:%100.000000
2017-04-22 22:54:37:807 : !!!!Done!!!!!!
2017-04-22 22:54:37:812 : process stdout:installer:PHASE:The software was successfully installed.
2017-04-22 22:54:37:813 : process stdout:installer: The upgrade was successful.
2017-04-22 22:54:37:813 : Installer output: installer: The upgrade was successful.
2017-04-22 22:54:37:814 : Exited
2017-04-22 22:54:37:814 : TStpInstPkgHandler::setup - Exit status 0
2017-04-22 22:54:37:814 : TStpInstPkgHandler::setup - Exit Complete
2017-04-22 22:54:37:986 : TStpInstPkgHandler::setup - started
2017-04-22 22:54:38:004 : Installer error stream: authinstalltool: beginning run
2017-04-22 22:54:38:005 : Installer error stream: authinstalltool: Checking self repair
2017-04-22 22:54:38:005 : Installer error stream: authinstalltool: reading command.
2017-04-22 22:54:38:005 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-04-22 22:54:38:006 : Sending marshaled authorization.
2017-04-22 22:54:38:006 : TStpInstPkgHandler::setup - install_volume = /
2017-04-22 22:54:38:006 : TStpInstPkgHandler::setup - write = 1
2017-04-22 22:54:38:010 : Installer error stream: authinstalltool: Should now have privileges.
2017-04-22 22:54:38:010 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-04-22 22:54:38:010 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-04-22 22:54:38:011 : Installer error stream: authinstalltool: Installing Install Flame.app/Contents/Resources/dist/adlmflexnetclient.pkg on target:/
2017-04-22 22:54:38:011 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame.app/Contents/Resources/dist/adlmflexnetclient.pkg -target / -verboseR
2017-04-22 22:54:38:473 : process stdout:installer: Package name is AdlmFlexnetClient
2017-04-22 22:54:38:473 : Installer output: installer: Package name is AdlmFlexnetClient
2017-04-22 22:54:38:473 : process stdout:installer: Upgrading at base path /
2017-04-22 22:54:38:474 : Installer output: installer: Upgrading at base path /
2017-04-22 22:54:38:474 : process stdout:installer:PHASE:Preparing for installation…
2017-04-22 22:54:38:481 : process stdout:installer:PHASE:Preparing the disk…
2017-04-22 22:54:38:495 : process stdout:installer:PHASE:Preparing AdlmFlexnetClient…
2017-04-22 22:54:38:507 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-04-22 22:54:38:508 : process stdout:installer:PHASE:Configuring the installation…
2017-04-22 22:54:38:508 : process stdout:installer:STATUS:
2017-04-22 22:54:38:509 : Installer Status:
2017-04-22 22:54:39:012 : process stdout:installer:%7.059257
2017-04-22 22:54:39:015 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:39:508 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:40:007 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:40:511 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:41:011 : process stdout:installer:%83.065352
2017-04-22 22:54:41:012 : process stdout:installer:PHASE:Running package scripts…
2017-04-22 22:54:41:507 : process stdout:installer:PHASE:Validating packages…
2017-04-22 22:54:42:518 : process stdout:installer:%97.750000
2017-04-22 22:54:42:520 : process stdout:installer:STATUS:Running installer actions…
2017-04-22 22:54:42:520 : Installer Status: Running installer actions…
2017-04-22 22:54:42:522 : process stdout:installer:STATUS:
2017-04-22 22:54:42:522 : Installer Status:
2017-04-22 22:54:42:522 : process stdout:installer:PHASE:Finishing the Installation…
2017-04-22 22:54:42:526 : process stdout:installer:STATUS:
2017-04-22 22:54:42:527 : Installer Status:
2017-04-22 22:54:42:527 : process stdout:installer:%100.000000
2017-04-22 22:54:42:527 : !!!!Done!!!!!!
2017-04-22 22:54:42:527 : process stdout:installer:PHASE:The software was successfully installed.
2017-04-22 22:54:42:528 : process stdout:installer: The upgrade was successful.
2017-04-22 22:54:42:528 : Installer output: installer: The upgrade was successful.
2017-04-22 22:54:42:529 : Exited
2017-04-22 22:54:42:529 : TStpInstPkgHandler::setup - Exit status 0
2017-04-22 22:54:42:529 : TStpInstPkgHandler::setup - Exit Complete
2017-04-22 22:54:42:690 : TStpInstPkgHandler::setup - started
2017-04-22 22:54:42:709 : Installer error stream: authinstalltool: beginning run
2017-04-22 22:54:42:709 : Installer error stream: authinstalltool: Checking self repair
2017-04-22 22:54:42:709 : Installer error stream: authinstalltool: reading command.
2017-04-22 22:54:42:710 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-04-22 22:54:42:710 : Sending marshaled authorization.
2017-04-22 22:54:42:710 : TStpInstPkgHandler::setup - install_volume = /
2017-04-22 22:54:42:710 : TStpInstPkgHandler::setup - write = 1
2017-04-22 22:54:42:715 : Installer error stream: authinstalltool: Should now have privileges.
2017-04-22 22:54:42:715 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-04-22 22:54:42:715 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-04-22 22:54:42:716 : Installer error stream: authinstalltool: Installing Install Flame.app/Contents/Resources/dist/Installer-Flame-2018.0.0-432.x86_64.mpkg on target:/
2017-04-22 22:54:42:716 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame.app/Contents/Resources/dist/Installer-Flame-2018.0.0-432.x86_64.mpkg -target / -verboseR
2017-04-22 22:54:47:668 : process stdout:installer: Package name is Autodesk Flame 2018 For Mac OS X
2017-04-22 22:54:47:669 : Installer output: installer: Package name is Autodesk Flame 2018 For Mac OS X
2017-04-22 22:54:47:669 : process stdout:installer: Upgrading at base path /
2017-04-22 22:54:47:669 : Installer output: installer: Upgrading at base path /
2017-04-22 22:54:47:669 : process stdout:installer:PHASE:Preparing for installation…
2017-04-22 22:54:47:922 : process stdout:installer:PHASE:Preparing the disk…
2017-04-22 22:54:47:937 : process stdout:installer:PHASE:Preparing Autodesk Flame 2018 For Mac OS X…
2017-04-22 22:54:47:950 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-04-22 22:54:47:951 : process stdout:installer:PHASE:Configuring the installation…
2017-04-22 22:54:47:951 : process stdout:installer:STATUS:
2017-04-22 22:54:47:952 : Installer Status:
2017-04-22 22:54:48:452 : process stdout:installer:%5.752557
2017-04-22 22:54:48:454 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:48:953 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:49:450 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:49:954 : process stdout:installer:%28.913122
2017-04-22 22:54:49:954 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:50:450 : process stdout:installer:%34.068236
2017-04-22 22:54:50:451 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:50:950 : process stdout:installer:PHASE:Writing files…
2017-04-22 22:54:51:452 : process stdout:installer:%50.792350
2017-04-22 22:54:51:455 : process stdout:installer:PHASE:Running package scripts…
2017-04-22 22:54:51:953 : process stdout:installer:%52.084490
2017-04-22 22:54:51:956 : process stdout:installer:PHASE:Running package scripts…
2017-04-22 22:54:52:452 : process stdout:installer:%57.962562
2017-04-22 22:54:52:455 : process stdout:installer:PHASE:Moving items into place…
2017-04-22 22:54:52:951 : process stdout:installer:%95.203678
2017-04-22 22:54:52:954 : process stdout:installer:PHASE:Cleaning up…
2017-04-22 22:54:53:454 : process stdout:installer:PHASE:Validating packages…
2017-04-22 22:54:53:967 : process stdout:installer:%97.750000
2017-04-22 22:54:53:971 : process stdout:installer:STATUS:Running installer actions…
2017-04-22 22:54:53:971 : Installer Status: Running installer actions…
2017-04-22 22:54:53:972 : process stdout:installer:STATUS:
2017-04-22 22:54:53:972 : Installer Status:
2017-04-22 22:54:53:972 : process stdout:installer:PHASE:Finishing the Installation…
2017-04-22 22:54:53:974 : process stdout:installer:STATUS:
2017-04-22 22:54:53:974 : Installer Status:
2017-04-22 22:54:53:974 : process stdout:installer:%100.000000
2017-04-22 22:54:53:975 : !!!!Done!!!!!!
2017-04-22 22:54:53:975 : process stdout:installer:PHASE:The software was successfully installed.
2017-04-22 22:54:53:975 : process stdout:installer: The upgrade was successful.
2017-04-22 22:54:53:976 : Installer output: installer: The upgrade was successful.
2017-04-22 22:54:53:979 : Exited
2017-04-22 22:54:53:979 : TStpInstPkgHandler::setup - Exit status 0
2017-04-22 22:54:53:980 : TStpInstPkgHandler::setup - Exit Complete
2017-04-22 22:54:54:153 : Running post-install script: ../Resources/dist/MACOSX-autodesk.postinstall
2017-04-22 22:54:54:327 : Running post install script ../Resources/dist/MACOSX-autodesk.postinstall
ERROR: executor does not exist.
End of script
2017-04-22 22:54:54:327 : pre/pos install launch results:
End of script
