I've noticed an issue recently with AAFs importing to Flame with the wrong timecodes, which means they don't relink to source media.
My AAFs are created from Avid along with an EDL
The EDL shows the correct start timecode - e.g. 00:01:38:04
The AAFs are offset by 24hrs, but exactly correct otherwise - e.g. 24:01:38:04
So I've been able to conform the media using the EDL, which is fine but doesn't carry over any compatible effects so I'd rather use an AAF.
I only noticed this happen recently and the AAF workflow has always been preferable until now.
I also tested various AAF export settings from Avid and get the same result each time.
Has anyone else experienced this, do you know what's could be causing it and how to solve it?
David
David
Hello David!
Please open a ticket with our support team so they can have a look at your AAF file.
Hello David!
