3d Shape question
3d Shape question
adamt
3d Shape question
adamt
Is there a way to generate a 3d Shape within Action using a Matte input instead of a GMask?
Flame 2020.3
Grant.Kay
Hi Adam,
The answer is no.   The 3D shapes are generated off the splines of the Gmask and cannot used with extrude a matte into a 3d shape.
As a suggestion, you could use displacement to displace a surface with the matte.   This wont give you a perfect shape but it might help if the movements are very minor.
Hope this helps.
Regards
Grant
Grant Kay
Principal Learning Content Developer
The Official Autodesk Flame Learning Channel
http://www.youtube.com/flamehowtos
The Official Autodesk Smoke Learning Channel
http://www.youtube.com/smokehowtos
Also available as podcasts on iTunes
Follow me on twitter @discreetuk for the latest training updates.
adamt
thanks Grant - had a feeling that was the case but worth asking anyway!
adam
Flame 2020.3
shiver_rayfresh
Hello Adamt,
Grant already answered you but if you want to use complex matte (picture) to use it with extrude / bevel, in Flame i suggest you this technic :
(you will need Illustrator)
1 - open your matte picture in Illustrator
2 - Vectorize it, fine tune the curves as you you need to have a clean curve
3 - export it as SVG file
4 - (Back in Flame) In Action, Import your SVG and you will be able to play with it in 3D with Depth, bevel, shader etc.
Have a nice day
Shiver
Grant.Kay
Shiver is absolutely correct...
If you use a 3rd party application to create an SVG vector file from the matte, you can import that into Action as a 3D shape and it can be extruded etc.
I might just use that idea and make a video with it in the future 🙂 . There are some illustrator settings which do catch ppl out.
Regards
Grant
Grant Kay
adamt
thanks both of you...its an intriguing idea. I had not tried svgs - i'd forgotten about them being in Flame, after so long using Smoke.
Unfortunately for the test i was doing its not really practical to build a shape in vectors, as i wanted to use the complex animations of matte channel coming of a greenscreen key to generate the shape....but still its a useful solution to know about.
adam
Flame 2020.3
