View problem in FeatureCAM
Work plane is not aligned with the view in Default settings as per shown in the screenshot below. We are facing the same issue in all the older projects too.
As per below Screen shot the top View is selected (ctrl+5) but the view of the part is not aligned with the top view. It is tilted at some angle.
link of video :- https://autode.sk/2z7xuY2
Kindly guide us.
clearing all the files from C:/Program Files. THEN reinstalling FeatureCAM now it is working fine.
abhishek.juvekar
Hi @Anonymous,
Thanks for raising your query via Autodesk Forum.
I was able to replicate what you are seeing in FeatureCAM. It seem you had selected a Perspective view. in View tab>ISO.
Perspective — If selected, the view is a perspective view. If deselected, the view is an orthographic view.
It might have saved in your INI files. So it was showing same results in other new turning documents as well.
Refer a video to overcome this issue. https://autode.sk/2m5qXE0
Hope it answers your question. Click on 'Accept as solution' button if my post answers your query.
Thank You.
Abhishek
@abhishek.juvekar
One of you colleague check our problem & said uninstall & then reinstall.
Krupal Vala
abhishek.juvekar
Hi @Anonymous,
I sincerely apologize on behalf of my colleague (although I don't know who advised to uninstall and reinstall). Now at least you have the solution which may help you if you came across a similar problem in future.
Thanks and have a great day!
Abhishek
@abhishek.juvekar
Thank you for a solution.
Krupal Vala
