- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
is there a way to thread mill NPT threads? Im programming for a 3 axis vertical mill.
Hello all,
You can certainly thread mill NPT threads but you will have to conventional mill because there is a bug that puts out bad code if you try to climb cut. I reported it in November 2017.... they haven't had time to fix it yet.
Does the code display bad in the machine? I just tried to climb mill 1/4-18 NPT threads in the latest FCam 2020 upgrade that I have and it seems to work ok onscreen and within the text editor.
It also ran thru the graphics of the 3 axis mill here in the shop as well with no errors. I just haven't actually cut a part with the program yet.
