Surface milling
Surface milling
Message 1 of 15
Surface milling
I cant send out a example but i need to mill a 1 inch square area with a .250 dia ball endmill. i need the tool to be angled at a 30 or 45 degree angle from the surface, the surface finish is 125. the square also has 2 corners that are rounded to .018, Someone showed me something about this but i dont have the information anymore. can someone help as i have tried everything i can think of and it doesn't work. the machine is a Mazak Vortex 5 axis mill.
Replies (14)
Message 2 of 15
hi ,
take a look at those two way to do this
the easyest way is by vector (fixe)
for the radius edge you can do this with vertial
i hope this can help you.
Message 3 of 15
Richard, Thank you for the reply but i do not see those options when i program the surface milling, i do have 5 axis programming on in the setup, maybe thats a function of the post processor? Any ideas on how i can see all the items you posted?
Message 4 of 15
you need Ultimate to do this
do you have it?
if yes ,you just have to activate 5axis in you stock properties and go to indexing and activate 5 axis
Message 5 of 15
wmtcoinc
Not sure if this works for you, but I machined a square cornered pocket on my 5 axis like this using swarf milling and a 60 degree tapered end mill .0005 end Diameter. I had to add fan surfaces to control the lateral movement and force the tool to move up and down in Z on the corners.   inside 90s.png
Message 6 of 15
I do have 5 axis on and i have ultimate, not sure if the post supports this. under indexing it says 5th-axis positioning is on.
Message 7 of 15
That wont work for what i am trying to do, i need the tool to machine the surface at a 45 degree angle
Message 8 of 15
it should be better for me to understand what you mean if you send me an example of your program
regards
Message 9 of 15
wmtcoinc
Creating a new setup at the 45 degree angle you need and than create the milling feature you want in it should work. I do that to when 3D milling on a 4th axis rotary.
Message 10 of 15
RichardLagace, i cant send out anything, i think you have the solution, i just need to figure out how to get those options you showed. if you do this, draw a square on the X-Y plane with Z at a 45 degre angle and try to machine the square with a 125 surface finish, I can machine the square at 90 degrees but i create another setup so the tool will machine at 45 degrees and it doenst work. so if you can figure out how to setup Feature cm so i can do this?
Message 11 of 15
you can do this with a setup at 45 deg,no problem
just clic on generate a single program for all setups  under indexing in stock properties
regards!
Message 12 of 15
Too all, i have contacted Sheila Cullers and i will send her my post processor that i use with Featurecam to see if it is really a 5 axis post.
Message 13 of 15
Tried it, i get, "unable to find any features from the surfaces"
Message 14 of 15
I have tried everything i can think of, cant get it to work
Message 15 of 15
chris.coleQDYFL
Hey, Joel.
Sheila got in touch with me, and I will be sending you something via email a little later on today.
Thanks!
Chris Cole
Senior Solutions Engineer
