Solid model tool holder issue
andrewg9X5A8
Message 1 of 10
andrewg9X5A8
I'm following all the instructions Autodesk has to offer for importing solid models for tool holder. Insert my solid model, create a copy of a tool and paste the solid or the curve into the area as well. Transforming the solid model part to line up with the example pasted. Returning to the tool holdering drawing tab and going solid > then selecting my new solid. The new tool cutter will show up in the preview window but will not save when I hit OK. It always reverts back to the default tool holder.
Replies (9)
Message 2 of 10
ChristopherMarion
Hi @andrewg9X5A8
Can you upload the 3d model of the tool holder you are trying to import?
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Message 3 of 10
gregorANU4T
I have the same issue, it just doesn't work when trying to add a model to an existing tool. I suspect it's related to which type of database you use. I have the FC database on an SQL server, how about you?
It saves the tool correctly if you create a new tool and add the model without ever leaving the new tool dialog, so I have just been doing that as a workaround.  PITA though.
Message 4 of 10
andrewg9X5A8
Yes sorry for being late but heres the tool file im trying to add
Message 5 of 10
ChristopherMarion
Hi @andrewg9X5A8
As @gregorANU4T mentioned in his earlier response.  Is this tool being saved into a local database or to a MS Access database or SQL database?
Christopher Marion
SolidCAD - Canada
Message 6 of 10
andrewg9X5A8
Pretty sure its a MS database. I can find out for sure tomorrow. Will that cause issues while saving?
Message 7 of 10
ChristopherMarion
Hi @andrewg9X5A8
I am assuming you have no issues saving other tools to your database.  If so, maybe you do not have permissions to save.  Just a thought!
I am sure your IT department can tell you if you have read/write access.
Christopher Marion
SolidCAD - Canada
Message 8 of 10
andrewg9X5A8
I'm able to import the file as a solid and everything. Its just after i press "ok" after setting my tool as a solid model that it reverts back to the generic tool. Thanks in advance
Message 9 of 10
andrewg9X5A8
Yea I was going to ask them tomorrow thank you. It wont replace a solid in a machine design file as well when replacing holders.
Message 10 of 10
Hello
Certainly just a formal error.
Try to open the app with administrator rights.
Then it should work too.
Best regards
Mathias Beyer
