Hi all,
how can I create slot operation with movements like in the picture.
Thank you.
Solved by brian_p1. Go to Solution.
Yes, it is roughing, but it doesn't matter i just need movements like first drawing on picture.
If you define it as a simple groove and set ramp angle to 0 degrees the it will do what i think you want it to do.
Is this what you wanted?
If can, please, someone from Autodesk to answer me,
why in Slot feature, when I define bi-directional milling, toolpath just work in one direction
and goes back in same level instead of go down for Z increment ant the back?
It's ok, I can go around with Groove like in @brian_p1 solution, but it doesn't make no sense.
Thank you in advance.
