Simulation Error
Simulation Error
Simulation Error
Whenever I run the simulation, the simulation ends without finishing the whole task. I do not how to explain it in detail that is why I have added the screenshot of the problem. The letter A and N is left unfinished. I am pretty new to FeatureCam
lee.hillman
Hi adnanhuxain
It's kind of difficult to guess the size of the part but it looks as if the tools are too large to finish the profile.
Assuming that the tool crib actually contains small enough tools
Look in Manufacturing >> Machining Attributes >> Mill >> Tool Selection >> Multiple Roughing Tools
At the bottom of the window
Is there a tick in the box next to
The minimum tool diameter of an automatically chosen Roughing tool is... (default is 5mm)
if so un-tick it
Hopefully that'll improve things
Best regards
Lee Hillman
kamalrajcv
Hi @Anonymous
I am looking at the unresolved forum posts.
Has the previous reply helped you solve the problem you were facing?
Do you need further help with this?
Can you please select the reply that solved your issue by clicking the "Accept Solution" button available under each reply?
Accepting a solution will mark your topic as solved, and highlight the reply in the topic so others having the same issue can more easily view the solution.
Kamalraj C V
Technical Support Specialist
