Siemens 840D post
Siemens 840D post
dames99
Siemens 840D post
dames99
Does anybody know what these two tolerances are for in the code for a Siemens 840D? See attached.
Thanks.
brian_p1
Not sure what the first tolerance is but the second one is the controls the rough/semi finish and finish cycles of the machine.
See attached pdf
dames99
Thanks Brian!
hi
the first one is a tolerance for machining ,your mill will make some move in respect to this tolerance,
even if you set a high feed if the move is too small  and not allowing this feed this one should be skipped
and done by a lower feedrate.
regards!
