Setup Sheet not showing set up images
Message 1 of 11
This may be my PC but im getting an error within the HTML document.
My PC is a Dell with windows 7 x64 running Autodesk FeatureCAM Ultimate 2019.
I have tried in multiple browsers with no luck in displaying the Setup Image on the setup sheets I create. Below is the error(using inspect right click) in any browser I use:
<img alt="Setup Image" src="ERROR: Could not open image file MEC10020R0_Images\MEC10020R0_Setup1.png">
Replies (10)
Message 2 of 11
rfuentes
the set up IMAGE folder has to be i n the same location as the SETUP SHEET FILE.
Message 3 of 11
Hello @rfuentes,
Thank you for your response, All files are on desktop within the designated folder.
I can see within the folder, HTML file, Setup Images, and Tool images (.BMP) all in one place, still no luck
Message 4 of 11
rfuentes
sounds like you have to edit the setup sheet html file.
Message 5 of 11
bhorstTGM48
Is this a new install / upgrade? Have you right clicked on the FC icon and selected "Run as Administrator"?
Message 6 of 11
Hello @bhorstTGM48,
Its a newer install of  Ultimate 2019, I have tried that with no luck.
I have access to a different pc with the software on it, Iam going to be trying the setup sheet add in and see if it works on that PC.
Thank you for your reply.
Ill post the results in the AM, its almost time to go for the day here.
Message 7 of 11
JC.Medina
Looks like the template might be bad. Attached is one that should work. You will have to change the extension from .txt to .html
src="http://images.autodesk.com/flashassets/staticassets/images/autodesk_logo_signature.png">
Cory.M
Message 8 of 11
@JC.Medina
How do I apply it?
Message 9 of 11
bhorstTGM48
C:\Program Files\Autodesk\FeatureCAM 2019\addins\SetupSheet
This should be the default location for your setup sheet. Copy and overwrite the new one.
Message 10 of 11
@bhorstTGM48,
Thank you
@JC.Medina
Did not work, see email. Thank you
Message 11 of 11
JC.Medina
Attaching the template that resolved the issue as the first one did not work.
Cory.M
