Setup Sheet not listing all the tools
Waltoft
Message 1 of 8
Waltoft
Hello all,
FeatureCam 2020.3.0,  Win 10 Pro
I have been using the attached customized SetupSheetTemplate for 2 years now and for 2 months with this version of Featurecam.  Always worked well until today.  Now it will not print out the last 2 tools into the setup sheet.
Anyone know what would be causing this?
Attached is the fm file it is happening on ( it has happened on 2 other fm files today as well ) and a screen grab of the bad output.
Replies (7)
Message 2 of 8
bhorstTGM48
https://www.screencast.com/t/SEWmTiUUCcC
It works fine with my custom setup sheet. Mine is a bit more simplistic than yours.
Message 3 of 8
bhorstTGM48
OH, FYI I did have the same results with yours.
Message 4 of 8
Waltoft
Thankyou for checking this.
Obviously it is something wrong with my setup sheet template then.
If possible could i have your template to see how it could be adapted?
Message 5 of 8
bhorstTGM48
Here it is, good luck.
Message 6 of 8
lee.hillman
Hello
It appears to be linked to the length of the tool names,
I shortened the names of the missing tools and they have now appeared using your template
The tool numbers are different as I have not remapped their positions
Message 7 of 8
Waltoft
Wow, great observation.  I have shortened the tool names and they appear fine.
The Feature Name also has a length restriction of 11 characters which is a real pain.  I never thought to check for a length restriction on any of the other fields.
Thanks again!
Message 8 of 8
bhorstTGM48
My setup sheet does not seem to have this restriction, it just adds another line.
