How do I leave both forms on the post processor featurecam lathe, circular motion, giving the ability to enable and disable as needed.
1option
{N <SEQ>} {<MOTION>} X <X-COORD> Z <Z-COORD> I <ARC-X> K <ARC-Z> {F <FEED>} <EOB>
2option
{N <SEQ>} {<MOTION>} X <X-COORD> Z <Z-COORD> R <S-RAD> {F <FEED>} <EOB>
Thank you very much in advance.
Solved by brian_p1. Go to Solution.
If you put 2 slashes in front of the code then it will not read it but can still be in your post processor for when you do need it.
Hope this helps?
1option
//{N <SEQ>} {<MOTION>} X <X-COORD> Z <Z-COORD> I <ARC-X> K <ARC-Z> {F <FEED>} <EOB>
2option
