New UCS set up error
tjacobse
tjacobse
I've been using Feature Ultimate 2019 now for approximately 6 months.  I noticed that when you create a new UCS set up it's a little different than 2018.  I've figured out how to use, but I experience an intermittent software glitch.  What I mean by a glitch is after I go through the set up wizard ( usually align to geometry) I select OK, I get this error. "Please enter a number or ****."  Does anyone else ever get this error?  Please help, it's driving me crazy!
Please see attachment.
Thank you
hi, everything work fine. please attach fm file  for better results. i am using this no problem.
abhishek.juvekar
Hi @tjacobse ,
Thanks for posting on Autodesk Forum.
 The root cause looks like a location that was set as a negative zero, causing the error.
Try removing the negative sign from the Y location in the existing version or it seems to be fixed in the latest release. Update it to FeatureCAM 2019.3.4.0012.
Hope this helps. If my post answers your query, please click on Accept as solution button.
Abhishek
tjacobse
Abhishek, You are correct! Thank you so much for your help on matter. I can't believe did see that negative value in the position box.
