Help Lathe Center Y Axis Simulation.
invapprentice
Message 1 of 1
invapprentice
 Hi guys:  I need help here.
Working on a Lathe Center with Y Axis Design. Anybody help Simulation of Y Axis?
1- I need to do the Simulation move along the lathe Y Axis. But no axis move is aligned with the real UCS Y Axis. I believe the real Y AXIS Move might be a combination of the lathe Y_Axis_Slide and the X_Axis_Slide simultaneously, but I have no idea of how to perform in that simulation.
2- Is it there any trick to keep Boring Tool Block and Boring Bars in place?  Tool Block moves out of its position                   and rotates 180 deg when Turret indexes it into position. (Images attached) Works perfect if holding drills on it.
Thanks in advance.
invapprentice.
Replies (0)
