Featurecam Turning
Featurecam Turning
thaont.cnc
Featurecam Turning
thaont.cnc
FeatureCAM can make turning same this video?
https://www.youtube.com/watch?v=YN_3I7k374g
Matthias.K
Yes, thats possible.
  1. create a curve of your thread geometry
  2. New Feature --> Turning --> Thread from path --> Select curve
  3. On the dimensions menue, select "custom" and if selected, deselect the option "thread path from curce"
  4. Select type "curve cross section"
  5. Now you can set the curve for your thread profile along with thread length and pitch
Thats it, hope it helped!
thaont.cnc
I tried it, but the tool is still small and cannot cut
Matthias.K
 Can you please attach you *FM File to have a look at it?
thaont.cnc
You can see FM file
Matthias.K
I think its all about your tool. Try using another (bigger) nose diameter and also use a modified 3D-holder instead of the standard 3D-modell. Seems like the holder is causing also a colisions.
Additionally reduce the value for X and Z step.
thaont.cnc
I tried changing the bigger tool. toolpath the save.
I think FC can't do it
