External editor for NC code
Externer Editor für NC Code
What are you using for that? What do you say to that? Does anyone have experience with this program? Or which ways do you use? Thank you in advance. Sincerely, Mathias Beyer
Was verwendet ihr dafür? Was sagt ihr zu dem? Hat jemand Erfahrungen mit diesem Programm? Oder welche Wege nutzt ihr? Danke im voraus. Mit freundlichen Grüßen Mathias Beyer
Which editor especially for Heidenhain recommend you to me?
Welchen Editor speziell für Heidenhain empfehlt ihr mir?
I was asking this question not too long ago. Since then I've realized that the Code Editor/Viewer that works best for me is the Multi Channel Editor that comes with Partmaker/FeatureCAM. If you do not want to use that then another one that I found useful was Notepad++. With Notepad++ you can do a search on the web for a syntax highlighter and it will have some basic G code highlights that you can go in and edit for your specific machine(s).
If you want to pay money for a code editor then Cimco Edit seems to be popular among those who use MasterCAM. At least that's the case here at my shop.
Keep in mind that when you're looking for a code editor it doesn't necessarily have to be specifically for G code. I'll list a few that come to mind but my experience with these are limited so I wouldn't be able to help much with getting them setup:
Sublime Text
Pycharm (originally designed for Python Language)
Atom
Matter of fact...here's a link to a quick Google search.
Link to Notepad++
Hope this helps out!
Best regards,
Cody
Thank you for your extensive explanation. I have to mention, NC - Code editor especially for Heidenhain. I vary between editor and user specific features. Or the PP with special changes in the form of custom formatting with template in order to comfortably use in the machine. What does it cost, because PP with personal customization in the form of better structure and automatic insertion of PGM parts that are always the same. Or is this included in a maintenance contract? In the whole forum, I have not found anything suitable. To all mentioned points.
Danke für Ihre umfangreiche Erklärung. Ich muss noch erwähnen, NC - Code editor speziell für Heidenhain. Ich schwanke zwischen Editor und Benutzer spezifische Features. Oder den PP mit speziellen Änderungen in Form angepasster Formatierung mit Vorlage, um in der Maschine komfortabel anzuwenden ist. Was kostet es, denn PP mit persönlichen Anpassung in Form von besserer Gliederungen und automatisches Einfügen von PGM Teilen, die immer gleich sind. Oder ist das inclusive bei einem Wartung Vertrag? Im ganzen Forum habe ich nichts treffendes dazu gefunden. Zu allen angesprochenen Punkten.
