Dongle on new computer without parallel port
timMVYWS
timMVYWS
I have a old version of Feature Cam (2006) that I have used without problems. It does everything I need, so I have never seen the need to upgrade. It requires a dongle plugged into a parallel port. I have replaced my old computer and the new one does not have a parallel port. I purchased a USB to parallel port cable, but have not been able to get Feature Cam to recognize the dongle through the adapter cable. Is this something that can be made to work?
bhorstTGM48
https://www.startech.com/en-us/cards-adapters/pci2s1p
Have you considered trying something like this?
timMVYWS
Problem is, the computer the company bought as a replacement is a Laptop not a desktop. 😞
AJHanson
Have you tried getting a hold of Feature Cam to see if they could send a USB dongle out for your laptop?
jeff_brower
We have a Dell docking station for one of our laptops that includes a parallel port, it's probably an older unit and we don't know if it would work with a dongle but it's an idea.
timMVYWS
Featurecam has underwent at least two buyouts that I know of since we purchased our 2006 version.
Delcam bought them out, then Autodesk bought out Delcam.
I have contacted Autodesk about upgrading Featurecam (cost in the range of $7,000) not a viable option.
I did not ask if they could offer anything that would allow me to continue to use old Featurecam on a new system.
I may try that, but I assume they would tell me they do not support software that is so old.
lesturf432
Community Visitor
Community Visitor
I understand the challenges you're facing with your old version of Feature Cam and the compatibility issues with the dongle and USB to parallel port cable. It's important to note that Autodesk may not https://lesturf.com officially support older versions of their software on modern hardware configurations. However, there are a few steps you can take to try and make it work. Ensure that you have installed the latest drivers for the USB to parallel port cable, following the manufacturer's instructions.
