Capping rads
Capping rads
Message 1 of 8
Capping rads
I attached a picture to show what I need to do.  I am new in the Featurecam world and like what I see.  I have a part that I need to cap a lot of rads on the top of ribs.  I am trying to find out what tool path I would use to do this.  Can somebody help me with this?  Than You
Replies (7)
Message 2 of 8
You could do it with a radius mill.  What I would do is use surface milling with Z Level finish and check Continuous Spiral in the Strategy tab.  You could also surface mill with a 3d Spiral process.
Message 3 of 8
abhishek.juvekar
Hi @Anonymous,
Agree with BALLARD_ROBERT_X. In fact I went ahead and created a similar part in FeatureCAM using its solid wizard and have created a sample toolpath with Z level finishing for your reference. I have attached the fm file herewith. Kindly have a look in to it and let me know if you need any further help.
If my post answers your query, please click on 'Accept as solution' button.
Thank You.
Abhishek
Message 4 of 8
I looked at your program and that is exactly what I am looking for.  On the part that I am working on the surfaces with the rads on them are on an angle.  When I try this tool path it does not want to do it.  It will not go around the wholes boss with a nice spiral tool path.  It only does sections.
Message 5 of 8
abhishek.juvekar
Hello @Anonymous,
Is it possible for you to provide fm file? You can send me through private message if you don't want to disclose it on public forum.
Thank You
Abhishek
Message 6 of 8
I attached the file so you can look at it.  I have to cut all the rads on top of all the ribs.  I put one tool path on it so you see what I was trying to do.
Thank You for all your help
Message 7 of 8
abhishek.juvekar
Hi @Anonymous,
I am able to create a toolpath with 3d spiral on those radius. I was trying with Z level but the toopath was not smooth as it is with 3d spiral. Can you please take a look in the attached fm file and let me know how it goes?
Thank You.
Abhishek
Message 8 of 8
Is this close enough?
