API programming, adding STL as stock
We can use STL file as stock in FeatureCAM
How to do that  using API?
I know how to import STL into document, how to reference it as a model (using it name), but I have no idea how to set this file as a stock.
Do you have any suggestions?
Thanks in advance
Janusz
nagamanickam_dharmalingam
Autodesk Support
Autodesk Support
@Anonymous
As you are visiting as a new member,Welcome to the Autodesk community!
Here i have explained in Video about creating the stock model using the imported STL file, and also referencing the same stock model to toolpath creation, The first toolpath explaining about without stock model reference,the second toolpath is explaining about with stock model ,and also giving the reference to the next rest machining toolpath,
Hope it will help you to clarify your query,
If i have misunderstood your query kindly add more information ,
kindly accept if my answer solved your query,or reply with additional details if the problem exist.
Best regards,
Nagamanickam dharmalingam
Best regards
Nagamanickam Dharmalingam
spencer.hardcastle
Hi @Anonymous,
Thanks for posting!
If you are looking for a way to set the stock using an stl model, this can be done using the code below.
    Dim doc As FMDocument
    Set doc = Application.ActiveDocument
    Dim stock As FMStock
    Set stock = doc.Stock
    Dim mystl As FMModel
    Set mystl = doc.Models.Item("primitive_from_points")
    stock.SetStockSolid(mystl)
If this answers your query, please accept this post as the solution. If not, please let me know.
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
