Add Pattern -> Bug or my mistake?
ilan1204
Message 1 of 1
ilan1204
hi
i am making a part on a multi turn/mill machine with b-axis (5axis compatible).
i want to do the operation with Polar (C-axis) and not using Y.
I am adding an Action process before the milling process with the command "usePolarInterpolation"
everything works fine but now i want to copy and turn the process using "Add new patter" and i choose the axis and the amount.
my problem is that only the first slot is performed using C-Axis but on the other slots it is using Y-Axis.
Any idea why?
i solved already my issue with a different approach, so i don really need a solution what i am asking is, is this a bug or am i doing it wrong?
i am including the file.
thanks,
ilan
Replies (0)
