Are you looking to convert to xyz it sounds like?
I believe the reason why the control points are not represented in xyz coordinates is that they represent the underlying geometry of the surface, rather than the final fixed position of the surface in 3D space. Each control point is defined by a sort of "set of parameters" that determine its position in the U, V, and Z (W) directions, where Z (W) is is obviously the depth/height.
To convert the control points to xyz coordinates, I think you need to apply a script that maps the surface from its parameter space (U, V, W) to 3D space (x, y, z). This gets a little outside my expertise but wouldn't it be something like this to basically append a "z" point to the field?:
import math
def init_control_points(pUCount, pVCount):
# Initialize an empty list to store the control points control_points = []
# Loop over each control point in the U and V directions for u in range(pUCount):
for v in range(pVCount):
# Calculate the x, y, and z coordinates of the control point
x = u * 2.0 / (pUCount - 1) - 1.0
y = v * 2.0 / (pVCount - 1) - 1.0
z = 0.0
# Add the control point to the list control_points.append((x, y, z))
return control_points
# Example usage: control_points = init_control_points(5, 4)
print(control_points)
Again, probably not exact enough but should be a good start.
RB Cameron, AIA, LEED AP, EDAC
Digital Practice Leader
