Hi, how do I show the opacity in the viewer?
Setup:
Software: 3dsmax 2017
Material: Standard Material
Diffuse Map: JPEG (Random Texture)
![diffuse_test_001.jpg diffuse_test_001.jpg](https://forums.autodesk.com/t5/image/serverpage/image-id/653987iA7D1B2BD546CD6B7/image-dimensions/100x100?v=v2)
Opacity Map: JPEG (Black and White Mask)
![opacity_test_001.jpg opacity_test_001.jpg](https://forums.autodesk.com/t5/image/serverpage/image-id/653986i26031F87A68C65D4/image-dimensions/100x100?v=v2)
Object: Default Box
![fbx_opacity_issue_3dsmax_view.jpg fbx_opacity_issue_3dsmax_view.jpg](https://forums.autodesk.com/t5/image/serverpage/image-id/653985i8C512F532DC4911C/image-dimensions/100x100?v=v2)
Export:
- FBX -> Autodesk Media & Entertainment preset
- Plugin Version: 2017.1 Release (244292)
Result:
Opacity is not visible..
![fbx_opacity_issue_fbxreview.jpg fbx_opacity_issue_fbxreview.jpg](https://forums.autodesk.com/t5/image/serverpage/image-id/653989iA464B843E30BCFA2/image-dimensions/200x171?v=v2)
