FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
FBX export issue
1 REPLY 1
351 Views, 1 Reply
FBX export issue
I'm facing a issue while exporting the file in fbx. I have used pose interpolators in this file so while exporting the file one leg is not getting its neutral pose.Screenshot 2021-05-21 163443.jpg
1 REPLY 1
kelly_hynes
One option to try is to bake the results of the pose interpolators using the following workflow:
Select the blendshape deformer belonging to the shape that also has a pose interpolator.
Choose Edit > Keys > Bake Simulation (default options).
Since the pose interpolator is essentially driving blendshape targets, the process should be no different than when using blendshapes alone (with no pose interpolator).  Then try to export.
Hope this helps,
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
