FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
Can't find material w/ FbxFileTexture anywhere in scene graph...
5 REPLIES 5
1653 Views, 5 Replies
I'm writing an FBX loader for our in-house 3D renderer using the FBX 2016 sdk.  I've been testing w/ various free FBX files from around the web created in various tools and came across one that, although it does have textures packaged with it, the textures don't *appear* to be attached to the FbxMaterials... so I'm wondering how else they could possibly be retrieved from the FBX file...
Here's a link to the FBX file I'm testing with (claims to be made in 3DS Max):
https://free3d.com/3d-model/bb8-35865.html
When I'm reading it in, I recursively search all the FbxNodes in the scene graph and for each node, I call node->GetMaterialCount()... then, I iterate over the materials using node->GetMaterial(i) where 'i' ranges from 0 to the number of materials for that node.  However, when I'm looking at the material properties (like FbxSurfaceMaterial::sDiffuse) and call property.GetSrcObjectCount<FbxFileTexture>() or property.GetSourceObjectCount<FbxLayeredTexture>(), the count is '0' for all the materials in the scene graph...
However, I'm pretty sure that the diffuse texture is referenced *somewhere* in the FBX file b.c. it is automatically applied when I load the FBX file into Blender 3D... also, you can grep the FBX file itself and find the texture file name...
I thought that all textures in FBX had to be associated with an FbxSurfaceMaterial property... Is there some other way to retrieve an FbxFileTexture for an FbxNode using the sdk?
Danrae
5 REPLIES 5
If you dump the FBX file with ImportScene.exe from the FBX SDK coding exmamples, you will see the textures are stored as ImageSequences.  This is part of FbxVideo.  I don't the know the reason for this, but it's not typical.  Nobody is looking for material textures in FbxVideo.
    Property Count: 15
        Property 0
            Display Name: ImageSequence
            Internal Name: ImageSequence
            Type: Bool
            Is Animatable: false
            Default Value: false
        Property 6
            Display Name: Path
            Internal Name: Path
            Type: XRefUrl
            Default Value: D:\3D\Models\STAR WARS\BB 8\Body diff MAP.jpg
Oh gosh haha - that's very strange... even stranger that Blender was able to apply the textures correctly... nice call to dump the data w/ that sample app!
I was also looking for reassurance that the approach I was taking (searching material properties for scene graph nodes) is in fact the only method I should worry about for retrieving textures associated w/ a mesh... so this was really helpful - thanks for your help!
Maybe the FBX file was exported from Blender.  I seem to recall Blender doing screwy things, like storing textures in video stills.
Nope, it looks like 3dsmax exported it with custom properties.  I don't expect anybody to use those properties except for 3dsmax.
	Material: 19063560, "Material::Material #28", "" {
		Version: 102
		ShadingModel: "unknown"
		MultiLayer: 0
		Properties70:  {
			P: "3dsMax|maps", "Compound", "", ""
			P: "3dsMax|maps|texmap_diffuse", "Reference", "", "A"
			P: "3dsMax|maps|texmap_diffuse_on", "Bool", "", "A",1
			P: "3dsMax|maps|texmap_diffuse_multiplier", "Float", "", "A",100
			P: "3dsMax|maps|texmap_reflection", "Reference", "", "A"
			P: "3dsMax|maps|texmap_reflection_on", "Bool", "", "A",1
			P: "3dsMax|maps|texmap_reflection_multiplier", "Float", "", "A",100
			P: "3dsMax|maps|texmap_refraction", "Reference", "", "A"
			P: "3dsMax|maps|texmap_refraction_on", "Bool", "", "A",1
			P: "3dsMax|maps|texmap_refraction_multiplier", "Float", "", "A",100
			P: "3dsMax|maps|texmap_bump", "Reference", "", "A"
etc..
It's certainly not standarized.
I have this trouble ,too.And I got the properties like you show but I can not get texture file name and path.Are they included in "texmap_diffuse" property? But what is the type "Reference" do ? How can I analysis the texture.I tried like this but it does not work:
FbxProperty texmapDiffuse = mat->FindProperty("texmap_diffuse");
FbxFileTexture* diffuseFileTexture = texmapDiffuse.Get<FbxFileTexture*>();
if (diffuseFileTexture!=NULL) {
printf("\t\tdiffuseFileTexture:%s\n",diffuseFileTexture->GetRelativeFileName());
Is there any thing wrong?
Please show me a correct way, thank you ~
