We must have the possibility to add more production information's to the assets. Then we can use them for simulation and optimization. Also this assets need to be used in the early stage of the process.
Workflow - define your stations include. all relevant properties - place them in your factory - do simulation/optimization - check locations of stations against the factory building - do optimization again.
Today the Process simulation has only icons - so no idea what it will be. If this process is final - you start again in ACA with the optimization (and you type in all the properties again).
Regards
Frank
